Trying to work the bugs out of my car and get it somewhat tuned. The HEI was dropping spark, and after a failed attempt with a Mallory ignition box I installed a Pertronix Flamethrower upgrade kit.
I think I finally got the timing right, where the car seems to run good. I set base timing around 8 degrees, and have 34 degrees all in at 3000rpm. The vacuum advance is set at about 10 degrees. The car will now rev past 5000rpm where before it would drop spark.
However, now it has developed a new issue where it backfires/pops at high RPM under heavy throttle. Would this indicate a lean condition? I don't know if its related to the timing adjustment or not. I had too much timing in it before.
