Longroof79 said:My buddy is using the Davis unified distributor in his 403 Olds Cutlass. I'm using the Accel Blueprint distributor with the same coil as the Davis unit. Taylor 8mm wires NGK V-power plugs. Otherwise nothing fancy.
I think the Davis unit would be a good choice. They set it up according to your cars specs.
that's the nice thing about the E curve...I can set up the curve any way I want with 2 dials in the distributor. I use this program to set it up
