you guys might remember me, i did a restoration, and small build of my 1983 cutlass a little over a year ago.
since ive done that, the car has been sitting at the top of my driveway, and i cant find the heart to get rid of it. recently i bought a 2004 ford lightning as my daily driver. ive done a few bolt on's and now i guess you could call me a closet ford guy.
but thats besides the point, after having that as my daily the cutlass just isnt enough for me anymore. i didnt go wild on the build last time, but everything was built right. so this time, i figure lets push it a little more. i am going to be driving this car on weekends and stuff, and probably go to the track a few times a year. so i sold an old c10 i had lying around, and today i bought this.
http://newyork.craigslist.org/lgi/pts/1613644214.html
i got the motor, headers, and starter for $3100, picked it up and hauled it home. right now the cutlass is sitting with a dead battery and a cracked radiator, i plan to have this project done by summer. i have a few needs, wants, and concerns.
first i want to pull the old motor, transmission, and rear out. im going to clean up the engine bay, and repaint it. i plan on removing the heat/ac. i have an msd system in the car already so that will stay, and ill clean up all of the other wiring. im going to send out my turbo 350 to get built, and my 3:73 rear to get built, with more gear of course. im not sure of the ratio i want yet , i was thinking of just 4:11's because this car will be driven on the street too. the turbo 350 works great now, but all it has is a b&m shift kit, and i need more than that for the new motor. now, i have several concerns with the following elements of this build.
Driveshaft:
all i have is stock right now, i saw one on gbodyparts.com, but it was pricey, any other good sources for one?
Fuel:
i have a stock fuel system. i was thinking of getting a larger fuel cell (15 gal.?) making my own lines, and dumping the entire old system. or sump the tank i have now, and go with new lines, and a new pump? any good sources for a fuel system? just something to be able to support this motor.
Brakes:
i was going to leave the brakes alone for now, drums in the rear, and if i want to later on i can convert to disc all around.
Suspension:
all i was going to do for now, was get rear drag springs for the rear, and i have eibach springs for the front. again, later on i can improve the suspension all around. ive seem some of the front end rebuilding kits, and upper and lower control arms and stuff, do you think i should do more that just springs? i have 4 bilstiens on the car now, but thats the only modification ive made.
Cooling:
i have a cracked radiator, so whats a good, large, aluminum radiator for g bodys? i also have a dual electric fan set-up that runs off of a relay for the car. should i go with an electric water pump? or a stock gm pump?
Dressing the front:
i want the motor to look nice of course, and since i am deleting the ac, whats a cost effective front pulley set-up for small blocks? i have seen whole kits for over $1000, i dont need chrome pulleys or anything, but something other than the stock set-up.
Mini Tub:
i want to cut away the inner lip of the wheel wells to make room for tires, what else can i get rid of back there? is tehre an old thread on a mini tub?
Roll cage:
the motor is rated at 500-700hp with 800tq. with a t-top car, im guessing i need at least a 4-point cage in there. i didnt want to have to rip apart my interior again, but its necessary now. any good kits out there for g bodys? ive seen the jegs one.
Motor mounts:
what motor mounts should i use? are stock ones okay for this motor?
Exhaust:
im not sure that the headers i bought will work, but i got them because they opened up to 3''. i have flowtech headers on the car now but they are 2 1/2''. if i can make these work, id like to go with a 3'' system. right now i have a custom 2 1/2'' system with borla mufflers. i feel that the borla sounds nice, but is a little restrictive. i dont need an elaborate exhaust system. i was thinking dumping the borlas under the car?
Weight:
are there any other things i can get rid of to cut some weight? im not looking for a 2,000lb car, but every bit helps.
so those are my main questions, and pretty much all i will be doing on this build, plus small things like paint a wheels, once all that is done. i know i have so many questions and i dont expect any 1 person to answer any mroe than 1 of those questions, but any advice would help. i am pretty experienced and have experienced people working with me, but not familiar with g bodys. well, thanks for any advice, and ill start ripping out the old motor this week.
Driveshaft:
Fuel:
Brakes:
Suspension:
Cooling:
Dressing the front:
Mini Tub:
Roll cage:
Motor mounts:
Exhaust:
Weight:
