im swapping from a 200r4 to a th350
ridinhighgbody
9
im upgrading from a 229 and a 200r4 to a 305 and th350. im wondering if the flywheel will work with the th350 trans? i know i need a new torque converter but i wanna make sure i dont need a new flywheel. thanks
why do you want to swap the transmissions in the first place? The 2004r is a great trans??? Is it blown?
They use a 153 or a 168 tooth flywheel. Are you useing the motor and transmission from the same car? If so you shouldnt have to change anything. Why do you need a new torque converter? Also remember your switching from a od transmission to a 3 spd transmission and they also use different shift cables and probably kickdown cables. I don't really like my 200 4r either, this summer I'm probably going to a 350turbo as well. At least till I get my new motor/trans combo togeather. Good luck
the 305 i got has 7 bolts where the trans hooks in. the current motor and transmission only have six thats why i need to swap it.
Not all 200r4's came with the dual pattern.
Your right but the only single bolt pattern 2004r was behind a 2.8 60 deg V6.
They are almost non existent so I stand corrected.
If you can find one the Smithsonian Museum would probably love to talk to you. 🙂
