I've had excellent results with SEM products over the years, but the parts must be completely free of any surface contaminants and the application must be done per the instructions.
It sounds like the surfaces you're painting are still contaminated with silicone, wax or some other residue.
Make sure you exactly follow the paint manufacturer's instructions. I have had my best results when I use quick wipe with either lacquer thinner or IPA (isopropyl alcohol) before applying the adhesion promoter (ad-pro). Be sure to use an ad-pro that is specifically designed to be compatible with the color coat you're applying.
