Is it the UCA or the Spring???
I need some help y’all, I’m building a bracket car for the wife and I’ve run into an interesting situation. Long story short, the new springs have pushed the car to the stops on the UCA. I’ve tried two different sets Moroso “Trick Springs” currently on the 47130 spring. This is the lightest spring Moroso sells for our cars and it’s still on the upper stops with the motor installed (see pics). Too many folks run this spring for it to be the issue (I think…). So now I wonder about the design of the Summit brand UCA? When my buddy and I (400lbs total) stand on the frame horns I only get about 1” of drop. I won’t be adding that much back to the car in sheet metal, WTH??? Here is the current configuration with links to the parts being used, any help / recommendations would be much appreciated
Stock LCA
Stock Spindle
Summit UCA
http://www.summitracing.com/parts/sum-7 ... /el-camino
Moroso Trick Spring (frt)
http://www.summitracing.com/parts/mor-47130
Competition Eng. Drag Shock (3 way adj.)
http://www.summitracing.com/parts/cee-2 ... /el-camino
Stock LCA
Stock Spindle
Summit UCA
