Not 100% this should be in the how-to section. Depending on response I guess it could be.
My situation; I installed AEM Wideband on the car and finally got it hooked up this morning for the drive into work. I have started to manually record my readings and they seem ok to me. All the basics are done. Timing 34 deg all-in by appx 3000 rpms. Premium fuel. Carb set at the curb by highest vacuum reading at intake.
Motor
350ci SBC, est 10:1 comp, xr270hr retro roller camshaft, 1:6 rocker arms, patriot vortec heads, 1906 Qjet, dual snorkel air cleaner ( this I noticed as an improvement over stock via the butt dyno ), TES headers & Cat-back 2.5" exhaust
Trans-200r4 - Rear 3.73 with Auburn Posi - Tires 235-60-15 all around
Reading thus far
Cold Idle - 13.5
Cold cruise - 13.3
Cold wot - n/a
Warm Idle - 13.3
Warm Cruise - 13.0
Warm WOT - 17 to 15
When I slow to stop at a light the reading will drop to 10 or 11 for a few moments. Obviously I will data log for another couple days before any changes. But where do I take these numbers from here ? Fatten up the fuel mixture a little at idle and swap in the smaller rear jets on the rear hangers for more fuel at WOT ? I am also curious how running the AC and humid summer days will effect the A/F on the car.
Motor
Reading thus far
Cold Idle - 13.5
Cold cruise - 13.3
Cold wot - n/a
Warm Idle - 13.3
Warm Cruise - 13.0
Warm WOT - 17 to 15
