Judging by this picture I took and comparing it to the passenger side, my drivers window needs to be tilted inwards to stop that stupid blow out and not being able to unroll and roll it back up at highway speeds. The passenger window does not have this issue at all. I do know the drivers side was hit by a plow at low speed in a parking lot and resprayed at some point, so the door itself may be bent/broken. Even after adjusting/bending the window felts to take the flop out of the window, it still catches the tab when shutting the door and has the aforementioned blowout problem.
Question: is there an in/out adjustment to the glass at all? If not, is there a way I could make it have such an adjustment?
in the photo you can see the glass does not go up the middle of the seal top to bottom, but rides the outside edge and is directly on the inner side of the antiblow clip. The passenger side is more in the middle of the seal.
