is this bent and where does it go
jeremyandthemonte
731
150
Hello all I am putting my shiffter in and remembered I needed this bracket but is it bent and should strqight
Scrape that thing clean.. stick it in a vise... straighten it out...and hit it with a rattle can.
Reactions: V8 Rumble
So I made it straight but does not seem to work holes don't line up anywhere nore does the cable go in any suggestions?
I have a 1987 cutlass with a 350/350 combo from a mid 70s truck I think I am using the cutlass floor shifter cable and brackets but they don't work so any advice?
What trans are you using, and where did that bracket come from? I'm assuming it's not for the transmission you're using.
Is the shifter from the Cutlass for a 200-4R? If it is, you'll either need a cable and bracket for a TH350. The cable from a 200-4R will not fit a TH350 bracket.
That's what I'm using currently. I have a 4-spd shifter, with a 3-spd cable and cable bracket.
It's temporary until the 200-4R goes in.
