you know the drill. you fix it up you get it how you like it and then the little things start popping up.
i hate the lights in the dash. first i had one go out only to come back on later, so i have a connection problem. great, another problem to take care of when i put gauges in. i also discovered tonite my right turn signal light bulb has blown. GREAT!!!! i knew i should have redone all the light the last time i tore the dash apart but no! i insisted on making shortcuts and doing the bare minimum when i put the tach in.
they have these LED bulbs for the 194 bulb and im thinking of trying them out and if they're brighter or more white than the regular bulbs i'll switch over to them. the bulbs in the dash arent bright enough and i measured the ohms in a couple different bulbs including the 194 and i found the 194, while not the original bulbs in the dash, are brighter and IMO a much needed upgrade.
i wrote up an entire article on the lighting of the dash and what bulbs to upgrade to but i forgot all that info so im not able to impart my knowledge of this onto any of you.
the bulbs are 194 and upgraded to 168. jesus i forget so much crap its unreal. i just checked...i was wrong.
