So my cutlass is slow as a bad of snails and it also uses a lot of gas Ifeel like Ihae toi put gas in it everyday. Any ideas on how to make it faster for cheap right now . I got my tail beat by a super old honda ......smh. Any advice on howto get better accelration and gas mileage would be appreciated ! Thanks in advance .
A Buick 350 is a direct swap. You will gain a lot of torque and might actually gain mileage. An Olds 350 or 403 is also a good swap. An LS swap might be the way the go but requires modifications. Many have gained mileage due to their modern head design. Plus the 5.3 comes factory with 300+hp/tq and are very easy to find.
Even old Hondas have more hp and weigh less. Don't pick fights you can't win. The 3.8 was made to get you from A-B reliably with mediocre economy. If you don't expect too much out of it and you won't be too disappointed. Some have reported low 20s but my real world experience is that high teens is the norm with mixed city/highway driving. If you need to go faster -- you'll need more displacement.
you probably also have a highway gear in the rear end which causes you to use more gas in the city and you have a 350 transmission which takes about 20 - 25 hp to run
you do save money with the v6 if you drive it like its a v6. with most of these 3.8 cars having dead gears, if you put the pedal down you are going to rip through gas like any v8
