The CORRECT springs finally came from summit today. I will be putting these on along with my new front calipers, ceramic pads, and stainless brake lines to top off my manual brake swap.
I am having issues getting this fuel system to work. The pump is a eldebrock 1711 pump ran off the block. I bought this pump NIB for cheap so this is what I have to work with. I went with an off the shelf feed neck from summit to feed the 750 Holly. My vision was to come out of the pump and put the regulator right at the end of the feed neck. I would then make a bracket off the intake to support the extra weight from the regulator. After a quick mock up, I feel that the fuel line going down to the pump is to close for my own comfort. Can you guys shoot me a pm of a picture of your current fuel system if they are similar. I am running all stainless lines with AN-6 fittings.
Thanks, Cory
BTW picked up a set of electric fans from the yard Saturday!
