If you don't want to replace it, You can maybe use a shim to tighten the "gap" that the burnt out bushings caused, this may remove any play in the ends.
The later year jeeps have vented shafts that don't need heating, these shafts have a rubber peice On the outside in the middle
Keep in mind, on the Astro shafts, the column end has to be removed and turned 90 degrees then welded
They aren't s direct bolt on.
you do not reweld anything,
wow, hopefully that joint doesn't move on you.
