olds307 and 403
The Dodge Stratus fans fit well with the Cutlass top bracket and move a lot of air.
That'd be a nice setup. I like the factory look of the Cutlass top plate. I don't necessarily mind fabbing some brackets, but I don't want to have to scratch build a fan/rad setup and I want things to be neat and factory-looking.The Dodge Stratus fans fit well with the Cutlass top bracket and move a lot of air.
This?That'd be a nice setup. I like the factory look of the Cutlass top plate. I don't necessarily mind fabbing some brackets, but I don't want to have to scratch build a fan/rad setup and I want things to be neat and factory-looking.
Got the fuel pump installed today. Also found out that a non-A/C alternator bracket exists, and I found one over on V8Buick.com from a member. Should look much nicer than the bracket from the V6 or the either of the ones from the V8s. Little steps.
Yep that. I'm ditching the A/C so I think that should be the cleanest appearing setup.This?
If my car wasn't ac I would have definitely went this route. Would have let me use the Buick dual snorkel air cleaner too.
Yup. And nope.Yep that. I'm ditching the A/C so I think that should be the cleanest appearing setup.
Wait there is a dual snorkel air cleaner?! You aren't referring to the "star wars" air cleaner are you?
They make a 350-4 "HI-COMRESSION" as well.Ohhhh that dual snorkel air cleaner. I'm not sure what I'm gonna do for an air cleaner yet. I have the factory one off of the 76 LeSabre. It needs blasted and painted though and I don't really want to use the heat riser thing, so I don't know. I think I'm going to go with the black TA valve covers and I think this air cleaner would go well with them-
With this decal-View attachment 117827
