SilverShadow87 said:307 with an electronic carb on it... it gets fuel just fine in first, in fact plenty of it..
i was having the same problem but i think i just figured it out. my issue ended up being a hidden vacume line that was disconnected and another that was loose but still looked like it was hooked up. im noticing the carbs on these things along with the emmissions stuff are very finicky , so much that even one connected but not tight vacume line was enough to trip the check engine light and make it seem that my trans was shifting early. but since you have a th350 i cant say that we are having the same problem. wait dont th350s have a vacume line that goes to the trans? if there is which im pretty sure it has one , if its blocked or cut it would mess with the shifting.
