I'm having difficulty figuring out where the transmission pan is
Sent from my SM-G955W using Tapatalk
I think it's in the trunk area right? 😉...you're having trouble finding where the pan is? what?
Transmission pan...you're having trouble finding where the pan is? what?
I was gonna draw up a diagram, but climb under the car. Locate the transmission. engine in front, long thing out back is the driveshaft Trans is right in the middle. If the pan is shaped like Nevada (square with one corner cut off), it's either a Th350 or a TH200c. If it's a Th200c, it should say METRIC on the pan. Oh, the pan is under the transmission.Transmission pan
Welcome to the club! Good luck on the project.Just got my first ever car! I've always loved G-bodies, and this is a bad *ss whip!
Has 31,*** original KMs, a new 350, and also a completely reupholstered interior with no bench seat in the front anymore!
I just straight piped the other day and it sounds freaking nuts, it'll be temporary, as I'll buy a new exhaust down the road, probably magnaflows, but I'll check out others, too.
I want to push this bad boy to at least 420ish HP. It has around 350 at the moment, but what Cams and headers would you suggest?
Also, it's the stock transmission, but I can't figure out if that's the 200-4r or not
Thanks for reading!![]()
Nope. That'd be a th200r4. Th200c is a three speed.Could be the 200C trans too if it's a 4 speed. I didn't see that gasket shown
