OK this is where I get lost I guess .... y'all keep saying 305 and torque .... 305s aren't exactly known to produce good low end torque figures. Want torque? get a Caddy or an Olds.
jmangham said:I do not think this one has the ccc fuel system, pretty certain.
jmangham said:My carb is def not the ccc. oe number is 17059222. I am planning on replacing the transmission, just dont know how many 200-4r's are lying around here. I will keep a lookout though, 4th gear would be nice. I talked to the guy today and he still has the vortec 350. He has a cast iron vortec carb intake for a marine application. It is not mounted, he just has it. He bought it to run in a class where they could use vortec heads, but had to keep the cast iron manifold, go figure. He also replaced the intake gaskets and rod bearings just to be safe. said it had around 100 thousand miles on it. I would have been into the 305 for much more than the cost of this running motor, and now I will have a much better platform to build upon. Thanks again for the info.
Question, will the 200-4r "drop right in" as far as crossmember and driveshaft?
and
Would this oe carb (after rebuild) be enough for the 350?
Doober said:If you buy the Vortec, I have one thing to say: XE268H. It's 100% streetable, awesome torque, and you'll be shocked how hard it runs. Other than putting a carbed intake on you don't have to make any other internal changes to the engine.
http://www.youtube.com/watch?v=FwI9H1p574Q
