There was a debate going on, can a 12v key on power source be connected to the ignition wire that goes on the starter instead of going to a fusebox port for a electric fan?Thanks
The key on ignition source should only be powering the relay contacts (not the fans). The relay by itself will not cause the fuse to blow. As noted you need a fused heavy duty cable / power source directly from the battery also connected to your relay. Do you know how to read an electrical schematic? The red and yellow wires should be heavy gauge and rated properly for the fans current draw.Have that method but it keeps blowing fuses from a key on fuse in fusebox and ignition ports
Sounds like you have it wired wrong.Have that method but it keeps blowing fuses from a key on fuse in fusebox and ignition ports
