Landau top clips
mr evil
Aug 4, 2009
857
544
Sooke, BC, Canada
Are you in a hurry to get the clips? I’m getting ready to get rid of my landau top on my 87 regal. I can see if they will work for you?
I'll have a look and see if I have any as well.....maybe we can save you some headache.
Edit: So I went and took a look at what I put away. I have about a dozen of the ones for over the top that should work, but I only have 2 of the type used for the B pillar sides.....if memory serves, those are the ones I was able to find new though(I'll try to hunt the Geno/Auveco number for you). I also have a couple of each of the smaller ones used below the side windows and lower back window.
This of course helps only if the clips are same for Cutlass and Regal, which I'm sure they are.
Street Sweeper22
233
91
I appreciate your help. I’ve been working on this car for about three years so it will be nice to finish a piece of the project. The part numbers I have are 20215547 for the top and 20215548 for the B pillar. I hope they’re the same but I don’t know much about the Cutlass.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
My side clips didn’t come off nicely. Tops were good though. Let me know if these are what you are looking for.
mr evil
Aug 4, 2009
857
544
Sooke, BC, Canada
Here is what I have, they look a little different so maybe I can't help. IMG_4613[1].JPG
Haven't been able to figure out where or if I was able to get the side clips new....
Street Sweeper22
233
91
Here is what I have, they look a little different so maybe I can't help. View attachment 78079
They do look different. Mine have a part number on them. It’s small and hard to see. The ones up top look like they will work but it’s hard to tell. I’ve had no luck finding a vendor. Everybody had disconnected them.
mr evil
Aug 4, 2009
857
544
Sooke, BC, Canada
I always thought most of the mid-body stuff was the same between Cutlass and Regal, now I know better. My clips have no number on them that I can see. I haven't had any luck with your numbers either so I could only suggest calling around to see if any vendor has some old stock around or find enough decent used ones. Post up in wanted section here, must be more guys that have pulled them off.
Street Sweeper22
233
91
Ok thanks for the help mr evil
