Leak
87cuttdawg
87cuttdawg
13
Tennessee
#1
Coolant leaking from behind engine ?? What is this????
7
78chevolds
Jun 25, 2013
87
17
8
#2
Is this an Olds' motor? Likely the intake manifold gaskets. I had a leak in the rear right side. Common issue with Olds engines.
airboatgreg
airboatgreg
1,431
1,318
Freeze plug?
87cuttdawg
87cuttdawg
13
Tennessee
#4
Yes its an olds 307 i noticed a hole in one of my freeze plugs trying to figure out how to remove my dipstick tube so I can change it and see if its that or the gaskets
87cuttdawg
87cuttdawg
13
Tennessee
#5
Come to find out thats exactly what it is got under and noticed a hole in one of em. Trying to change it now can't figure how to get the dipstick tube out the way
airboatgreg
airboatgreg
1,431
1,318
The dipstick tube pulls out but you have to see if you can turn it a bit first, spray carb cleaner, twist and work in and out to remove it. Will ruin your day if you break it
airboatgreg
airboatgreg
1,431
1,318
Might think of going a brass freeze plug replacement
Thread starter Similar threads Forum Replies Date
Bonnewagon Cooling / Heating / AC 9
bill cook Cooling / Heating / AC 8
JAMES L EUBANK Cooling / Heating / AC 4
Similar threads
