Leak
78chevolds
126
50
Is this an Olds' motor? Likely the intake manifold gaskets. I had a leak in the rear right side. Common issue with Olds engines.
87cuttdawg
19
4
Tennessee
Yes its an olds 307 i noticed a hole in one of my freeze plugs trying to figure out how to remove my dipstick tube so I can change it and see if its that or the gaskets
airboatgreg
2,868
3,115
The dipstick tube pulls out but you have to see if you can turn it a bit first, spray carb cleaner, twist and work in and out to remove it. Will ruin your day if you break it
