LED Dash Lights
ryanelco said:
no way, im in levittown. we gotta meet up one day, let me know how the lights go.
no way, hah yeahh def.
join LIgbodys.com
anther good forum for all g bodys on LI
Blake442 said:
I've read that they only made 300 or so of them in white. Either way, it's definately a rare color combo. Keep it clean!
Yeah thats what i ment to say. I also have t-tops w. grey interior so that makes it even rarer. I would love to kno exact production numbers
Thanx! im trying lol
Question:
easiest way to get the cluster out is..?
Thanx!
Getting the cluster out is pretty easy:there are 2 panels you need to pull out.Something like a flathead screwdriver will work.Gently pry out the one covering the light switch and the one on the other side/some have a clock,some have rear defog/some have a rocket symbol.once those are out.there is 3 i think 9/32 bolts behind them and on the bottom of the dash pad i think there is 5 more bolts.once thats out there is 4 bolts holding the dash cluster in.
getting power
where would some places to get power? an if at the fuse box how would you do that? also do you just run in series after the first resistor
Do the LEDs work the same with the dimmer?
