Level 1 build thread....
I spray SEM low luster clear over mine for added protection and to kill the gloss.
Figured I’d use the passenger kick panel to hid the fuse block since the original computer ia being removed. I wouldn’t usually install a teach in a pillar pod but I wandered the keep the original cluster in one piece and actually need it because of the trans being MVB.
I will add another AEM gauge to the console. Likely trans temp
I trimmed the pillar pod a bit too much down near the bottom where it meets the dash but will cover it with something so no one notices 😔
Can someone tell me what that electrical part is laying on the carpet. It was attached to the passenger lock panel. What does it control?
It is the power door lock relay and will not work unless the housing is grounded/ mounted to the body.
Thanks! I sure am glad I didn’t cut that out..
