lift my cutlass
Black Rose
49
Hey GB's i want to lift my 86 salon supreme up a little and through 22's on it
how much should i lift it any ideas out there?
Qdub24
1,796
785
Columbus, GA
None. No lift is required for 22s or 24s.
Qdub24
1,796
785
Columbus, GA
My opinion is stock height or lowered. 22s aren't that big.
Qdub24
1,796
785
Columbus, GA
g-body4life1987 said:
my cutlass damn sure needs a lift in the front for 22's every time i hit a bump the tires go in the fenders
Does your car still have the original stock springs and shocks in it from when it rolled off of the assembly line? Or do you have fat, truck tires?
Qdub24
1,796
785
Columbus, GA
All Motor Boys said:
You don't need to lift for 22's if the suspension is at normal ride height the car will look great.
Exactly!
crucial118
1,055
51
48
MARYLAND, DMV
So what size tires are good for 22s on g-bodies, front and rear without a lift?
Qdub24
1,796
785
Columbus, GA
Nothing higher than a 35 series tire, or wider than a 275 series. Offset/backspacing of the wheels is still the most important factor in the equation.
This is how my car sat on 265/35/22s w/old, worn, stock suspension from 1983 in January 2009.
