Since I seem to build my car at a rate that is best measured in geologic time rather than with a calendar, I have started planning my future 5 speed swap now. I have a Borg Warner T-5 (3 of them!) and I plan to use it in the Olds behind my 350 Chevy 2 piece seal engine. I was thinking about using a lightweight flywheel to cut back on parasitic losses, but am unsure of the benefits outweigh the costs. I figure I have several flywheel choices (153 tooth). 1 would be a standard weight flywheel, next would be the lightweight GM flywheel used in the L69 Camaro/Firebird, lastly there is an aluminum flywheel with a steel friction surface. I am wondering if there are significant enough benefits to any of these on a relatively mild 350. Your thoughts are welcome.
As an aside, part of my design philosophy with this car is to improve performance and fuel economy without sacrificing driveability by improving overall efficiency. This is why the flywheel is intriguing as it would not significantly degrade idle quality or low end torque.
