Ok so I got all the adapters and lines to install my line lock. Hers the question. I got a factory dia hard line but it has smaller fittings with adapters I have to use to get the fitting large enough to plumb into the master cylinder. It's 3/16 line. I also git lines with proper size fittings but the line dia is larger than stock. So should I run the larger line with right fittings to the line lock from master cylinder or run the 3/16 line with adapters from line lock with adapters?
