DO GBODY DOORS LOCK YOU AND PUSH THE ELC. SWITCH DOWN? OR DO THEY JUST UNLOCK THEM . I REPLACE BOTH MOTORS AND STILL WON'T LOCK? WHATS THE DEAL WITH THEM
heheheh85 Cutlass Brougham said:It would appear that, unlike your caps lock key, the switch does not work. So, the next thing you need to do is make sure your caps lock is off. After that, you should take out the switch and test it with a volt ohm meter for continuity.
thanks im try that today. both motors are new. they might be defected orIhaveNoPantsOn said:heheheh85 Cutlass Brougham said:It would appear that, unlike your caps lock key, the switch does not work. So, the next thing you need to do is make sure your caps lock is off. After that, you should take out the switch and test it with a volt ohm meter for continuity.
checked both actuators and nothin in check the switches next and see what happensDrRansom442 said:2 brand new actuators defective? Even Auto Zone's quality control should be better than that. I'd be checking the cheapie switches and/or wiring. Of all the things I've replaced on my 2 Cutlass (Salon was manual windows/locks) .... I've enver done actuators .... replaced switch after switch and done window regulators but never door lock actuators.
i dont hear nothing no noise at all. going to try ur idea next . thanks for the tipspeteyb said:Are they making the sound like they're trying to lock - or are they doing nothing at all? If they're not making a noise, then you may want to ohm out the wiring to make sure you don't have a break. Get some test leads with alligator clips on each end and try to jumper each connector one at a time. The chances of having more than one wire broken is pretty slim. Good luck.
