Well, I definitely want air conditioning. Though, I imagine at some point my existing factory compressor (likely other components, too) will be replaced with . . I guess the Sanden ones are more efficient, and the most common/popular? I haven't done more than a few minutes of researching into this.
Back to the engines... I would like it to be 87-octane friendly, if that doesn't sacrifice too much in terms of power/efficiency/emissions (yeah, I don't necessarily HAVE to worry to much about that, but I'd LIKE to keep things clean and make the most of what fuel I'm burning). Since it's not going to be a daily driver, higher-octane requirements would be fine. That said, while 93 octane is very commonly available in NJ, I guess it's not in some other states, and who knows what'll happen in the future.
Now, 403 vs 455 - Let's see if I have the advantages/disadvantages right:
If I'm correct about the greater intake/exhaust options for the SBO, would the better intake-exhaust flow make up for the lesser cubes?
Also, does the lesser strength of the 403 make stroking (mildly) the engine a terrible idea?
At some point I will NOT be scattered all over the place on this! I swear!
- 455
- Pros
- Stronger block
- No cooling problems
- More torque easily attainable at lower RPMs
- Cons
- Possible hood clearance
- Drop air cleaner may be needed
- W/Z manifolds available, but still not as good as headers would be
- If going headers, there are very few options for BBO in G-body
- Pros
- 403
- Pros
- No fitment issues, and all brackets from 260 fit
- A little bit lighter
- Big bore will more easily allow for bigger valves/less shrouding (if needed)
- Better availability of intakes/a little more intake height clearance
- Better availability of headers/more options/long tube headers
- Cons
- Weaker block (but not an issue for my preferred idle-to 5000-ish max RPM range)
- Cooling problems?
- Fewer piston options (I would guess?)
- Pros
