YesYou are pushing axle housing up to the point, it's lifting the car and your shocks are too short to reach the mounting bolt?
moog cc507yes, I understand that. which wagon springs? what's the part # ?
Joe, If I ratchet the body down in order to make the shock connection, then the spring is now over compressed AND the shock is fully extended. At rest. The shock I am using is part of a lowering kit and I believe it is shorter than stock but cannot confirm this.good, those are the same ones I have in my wagon.
RAs Moog spring chart doesn't show an installation height, only a free height. that wagon spring is .75" taller compared to a sedan. when compared to your original spring, the new spring will be taller of course, because it's new and your original spring is old and sagged.
as for your issue with installation, I don't know. maybe its the way your installing them. I've always installed mine one a time and have never had an issue. I support the axle under the shock mount at the rear axle, disconnect the shock from the axle, lower the axle and swap out the spring, I then compress the spring till the shock will reattach. then repeat on other side.
hope this helps.
The shocks you have in your kit are listed on the RA website for gbodies. Also, all gbody frames are engineered the same where the rear shocks mount. Gm only changed the rear springs because wagons are heavier. While i apreciate your thoroughness of thinking through the problem. your missing the one thing not listed in the spec chart, new springs settle.Joe, If I ratchet the body down in order to make the shock connection, then the spring is now over compressed AND the shock is fully extended. At rest. The shock I am using is part of a lowering kit and I believe it is shorter than stock but cannot confirm this.
RA has a whole list of stock shocks. Only some of them provide dimensional info. The ones that do, vary by over an inch or more in some cases. The wagon springs were kind of buried in that list so I didn't know if there was a "known" longer set of shocks guys are running.
It sounds like you are using wagon springs and stock shocks without an issue. I will choose a pair and give it a try.
The shock would then act as a limiter strap. And from a visual standpoint it wouldnt allow the wagon spring to lift the rear which would go against what I'm looking to achieve. I have a few sets coming so I will play around. Later today I will try setting wheels directly on the ground and see if i can hook shocks up that way but I dont expect it to be any different than on the jack with suspension loaded. But its worth a try. Hopefully Im wrong I paid good money for these Bilsteins and dont wanna shelve themInstead of fretting about it, hook up the shocks, fill the gas tank and drive it.
Bonnewagon are the shock extensions safe? I assume so as you mentioned you were towing with this setup and had no issue. Just have to askWhat I get out of this is that you spent good money on shocks that don't fit now. OK- we've all been there. You have two options- one of which you are now enagegde in. Get some normal G-body shocks and be done with it. Or get extensions [ like 555bbchevy suggested] that mount up top and will drop the axle mount point down several inches. When I first did up my Bonnewagon I used 1979 Buick LeSabre HD springs that really raised up the rear. They worked well with the huge tires I had at the time. But the shocks were too short. I was using coil-over shocks and still had to use the extensions up top to reach the axle mounts. This worked out well as I was towing boats with this set-up. Later I stopped towing and put smaller tires on and the rear was up too high. I put some "HIgh Jacker" springs from JC Whitney which I still have on. They are a couple of inches taller than stock wagon springs and yet stock shocks fit perfectly.
