So I took the float bowl and metering block off to see what jets and power valve I have. The jets in front are two number 69 and the power valve is 4.5.
That power valve is way low I imagine unless that cam is lopey with lower vacuum.
Caution Long Post! Here is a copy of a quick guide to Holley tuning...
Part 1:
Tuning the float level
On Holleys this adjustment is very easy as it can be done without dismantling. With the engine idling take out the sight plug on the side of the fuel bowl. Be ready with a rag to catch the fuel that might run out if the float level is too high. With the sight plug removed, use a big screwdriver and a 5/8”/16mm wrench to adjust (the screw should just be loosened, adjustment is done on the nut). Adjust so that fuel is up to the level of the sight plug hole and just slowly trickles out. Note that if the level is too high and you adjust down, you have to wait until the fuel is consumed or trickled out, which can be an issue especially on the secondary fuel bowl. Also note that if you adjust down too low the nut loses its grip on the float bolt and when you try to get it back up it won’t work. In that situation, stop the engine, take off the screw and nut entirely and screw the float bolt up with your fingers. You may need a new gasket after doing this.
When both floats are adjusted as specified above, you can screw in the sight plugs.
Tuning the choke
Engine should be off during this session. Chokes are tuned by loosening the normally 3 screws, and then turning the round choke housing. Which direction is rich and which is lean is normally seen marked with arrows, if not, try turning it, and note when the choke plate closes (you may need to slightly open the throttle for the choke plate to move), that’s the rich condition, since closing for the air richens the fuel/air mixture, just what a cold engine likes. Try placing the choke housing in the middle of the scale. Then start the engine and drive a normal trip. Note that the engine has to be totally cold, this means not started for 4-5 hours. This means that testing several settings of the choke normally takes days, we often try a new setting when we come back from a trip, then leave it until next morning, and then test.
How does the engine behave. Is there a lot of smoke from exhaust it’s much too rich. If it stumbles, spits, and is not easy to drive, it’s too lean. If it runs fine, then you’re close, but you should try the next leaner setting until it starts to stumble, spit etc., because having too rich a choke setting costs fuel and fouls your spark plugs.
So choke tuning is really trial and error approach. Set it as lean as you can live with.
Tuning the idle mixture
Start with engine off and warm, the choke must have heated enough to not be affecting the fuel/air mixture. Slowly and softly turn the idle screws all the way in, noting how many turns. Make sure you down force them in too hard, it’ll ruin the finely tapered ends, and then you need new idle screws. Were they a similar amount of turns out? In the future they should be. Most carbs we dealt with should start the tuning 1-1½ turn out. If your carb ran fine and it was 2 turns out previously, start there. But in general, turn out both screw 1½ turn.
You now need to hook up your vacuum gauge. If you don’t have one, buy one, see section Vacuum gauge, the wonder tool. Most people that tune cars and don’t have a vacuum gauge, use the tach instead, but tuning based on rpm is a lot more difficult, inconclusive and inaccurate than tuning with vacuum. The vacuum gauge hose should be attached to a permanent vacuum port on the intake or on the carburetor. Do make sure it’s not ported vacuum, or on cars from the 70-80s with plenty of vacuum hoses, some were affected by temperature. Do use the correct port.
Start the engine and let it idle. Automatic transmission cars need to be in drive, so have a friend in the car with a foot on the brake, the parking brake is not sufficient. Look at the vacuum gauge. It should be high and steady. If the needle is floating back and forth more than 2-3 it’s rich. If it’s steady but occasionally drops a little, it’s too lean. If it’s totally steady you’re close to the right setting. If the needle does strange things, troubleshoot your engine.
Now turn the screws 1/8 of a turn. If the vacuum gauge indicates too lean, turn out and vice versa. If the needle is steady, turn in. Do both screws at the same time, then give the engine 30 seconds to settle with the setting. If you got a higher or a more steady vacuum, you’re going in the right direction, try once more. If not, try the other direction. Turn only 1/8 at a time, it’s a lot for the carb. When you get close to the absolute right setting, go to 1/16 increments.
Vacuum gauge Idle Action
Steady, high Good Try either direction for higher steady needle
Steady, high, occasional drop Lean Try 1/8 out until needle is steady with no drop
Floating more than 2-3 Rich Try 1/8 in until needle is steady
When this is done, you’ll end up with a strong steady idle and probably at a higher rpm. So you need to reduce the idle speed to the required level by adjusting the idle screw (not the idle mixture screws we just tuned…).
Some engines with long duration camshafts will not be able to obtain a high steady vacuum. On those engines you need to settle for the highest vacuum you can get, and it wont be 100% steady. That’s the price you pay for a long duration camshaft (but the idle sounds great).
Now you have tuned not only your idle, but also your 0-60 mph driving circuit, and if done correctly, the car will feel much stronger in that area. But as we see in part 2, we’re not satisfied with “feeling” faster, we will test and verify it..
