I currently have a 350 in my 81 Malibu with a Quadrajet.
It runs alright though I need to do some adjustments as the high idle isnt going down on its own right now. Otherwise seems fine. I do think the lifters are a bit noisy but dont know if thats a big concern or not.
Anyways, long term I want to do an LS Swap, but looking into it and just the way I am, I wont be satisfied going with a bare bones swap. I will want to rebuild it, custom harness, dress it up, etc so that is going to be very time consuming and expensive.
The Holley Sniper (QJet version), seems very appealing to me. I like the idea of a much more reliable and less finicky fuel system compared to carb. As well not having to worry about the silly heat riser valve, choke adjustments, etc. Driving in cooler weather reliably would be nice.
So I'm feeling pretty set on going that way (unless someone has some convincing arguments, which im open to).
I was hoping for some confirmation or advice on the parts I should go with.
Obviously, you need the Sniper EFI - https://www.holley.com/products/fue...sniper_efi/sniper_efi_quadrajet/parts/550-869
For fuel pump, I just got a brand new oem style tank last year, and after doing some reading, I think an in-tank pump would be better. This one sounded really good. https://www.holley.com/products/fue...uel_pumps/muscle_car_efi_modules/parts/12-306
The info on that pump says you can use the original hard lines, but I found some comments from people saying that because this is a returnless pump, the hardlines can cause some problems (surging? or something like that). And the solution was adding a pulse dampener. But some other comments saying running proper rubber hose instead of the hard lines would also solve this.
So I was thinking of going with this.
www.holley.com
Along with wiring and relay/fuse for the pump, and other misc items that come up, it would seem to me that this would cover everything for installing the Holley Sniper.
Would I be correct in that assumption?
Do you guys have an alternative part suggestions?
I am trying to keep costs as low as possible or at least not buy too many things that will become waste later on if I swap in an LS. I believe I'd be able to reuse the fuel pump and lines with an LS. and If I really wanted, I could get a carburetor style intake for an LS and use the Sniper on it, right?
Thanks guys
Holley EFI 526-9 Holley EFI Fuel System Kit
Holley EFI fuel kits are the perfect addition to your Sniper EFI or Holley EFI kit. They are engineered using a Holley fuel filter coupled with quality Earl's Vapor Guard plumbing to provide a fuel system tailored to the needs of your EFI System. The secret to Earl's Vapor Guard hose is in its...
Thanks guys
