I was just wondering if anyone knew how to fix the windows on these cars (or anything with similar style long, hardtop heavy door). Basically, when you open the door, I can grab the top of the window and wiggle it back and forth (about an inch of slack total). I know these cars (as well as Camaros, earlier A-bodies, etc.) were never perfect, but this just seems like something is very worn out.
Also, when driving at higher speeds, both side windows pop out at the top past the black stoppers at the tops of the a-pillars. Another thing that used to happen (not so much anymore) was that when I shut the driver's side door, the passenger side door window would pop out past the stopper.
My doors could use new hinge pins eventually, but they aren't too bad yet. The roof rail weatherstrips also probably need replaced. I figure fixing either one of those should help a little bit, but is there something inside the door that can be tightened or adjusted? I'm not familiar with working on these older types of doors that don't have a frame around the tops of the side windows. Any tips would be appreciated.
