How do I fix this? It's loose up and down. Can I tighten it up? It moves a lot vertically bot not side to side. It does have tilt if that helps and it just started happening recently. Thanks.
AJ88 said:Wow. Thanks. Looks like a huge pain in the *ss job. Is it dangerous at all to just leave it and drive it loose?
where are these allen keys if all that is involved is taking the wheel off that sounds simple....rustyroger said:The tilt column on my '79 Century worked loose, I removed the steering wheel and tightened the screws with a ball ended allen key. I didnt use thread locker, just tightened them up and they never came loose again. Took me an hour from start to finish.
Roger.
Dave V said:where are these allen keys if all that is involved is taking the wheel off that sounds simple....rustyroger said:The tilt column on my '79 Century worked loose, I removed the steering wheel and tightened the screws with a ball ended allen key. I didnt use thread locker, just tightened them up and they never came loose again. Took me an hour from start to finish.
Roger.
