http://cgi.ebay.com/ebaymotors/CHEVY-S1 ... 8033169687
if i order this is this all i need to lower my 87 cutlass supreme brougham
S-10s use the same spindles as G-body cars.
You can use lowering springs on the front also but you'll loose suspension travel and may also screw up handling if you go too low. The drop spindles keep the front suspension geometry the same.
