i have a 1983 olds cutlass. and I am trying put a ls2 engine and tranmission in it. I have the wiring har,drive by wire, two O2 sen, ecm, and maf. what wires I need to used the hook up the ecm in to the car.
stomis said:I think that CA is the only state you'd have trouble passing a truck motor off as a car motor. The 5.3 is virtually the same motor as the 5.7 ls1 just with a smaller bore. The block, design, emissions requirements, and all that jazz are exactly the same. The reason I say CA is the only state it would be an issue is because they love to check engine stampings on motors.
