Can the front crank seal be replaced without pulling off the timing cover? Every video I have seen does it in conjunction with replacing oil pump or timing chain. This is for my 2005 GMC Sierra with a 5.3. I don't want to pull the cover but if I have to I will change the Oil Pump and chain. Also, If I do change the pump, will I have to drop the pan? Looking for a quick fix since this is my DD.
