Yup, make sure the coils and injectors have power during cranking (pink circuit for most applications).
The computer and motor are from a 2002 Chevy extend a cab pickupSo you have a wire in the wrong spot not connected to cranking voltage. What year engine/harness are you using?
I installed a separate fuse block supplied from the battery with a 40 amp fuse. I believe they are on a 15 amp fuse in the new fuse blockSo you have a wire in the wrong spot not connected to cranking voltage. What year engine/harness are you using?
Sorry. My fat thumb hit the wrong thumb sorryYup, make sure the coils and injectors have power during cranking (pink circuit for most applications).
what if my cable shifter does not want to apply the park it stays on reverse? what can i do about that?
