LS to 2004R
ssn696
Living in the Past
5,671
7,002
Permanent Temporary
Question for the clever people. If I have a perfectly good 200-4R but decide to go the LS route, is there a known hack to use the ECU to apply TCC lock? The internal program is guaranteed to be wrong, and some wire splicing must happen. The other option is a standalone controller.
Guess who hasn't tried this yet?
<= THIS GUY!
First you need to choose "transmission non-electric". That said, it may need a PRNDL or P/N switch to allow it to activate. One of the reasons why I added a VSS was to see if the TCC can still be triggered by the PCM since it looks for road speed for engagement in 2-4. Additionally, certain codes may have to be turned off to avoid setting the CEL. Lastly, the TCC in the 4L60E should work on the same type of circuit as the 200-4R - but if it is inverted a relay can be used to swap the command from 12v to ground.
Yeah, I need to get back to work on the Monte.
Reactions: Tony1968
So it's as simple as picking off a switched circuit based on speed? What about engine load - kickdown from a higher gear...I should know this, but I'm not sure the old school transmissions make this choice mechanically.
That's the rub. Electronic controls do lots of stuff vacuum used to. I'd suggest a factory carb vacuum switch could be put inline to interrupt the circuit under low vac/boost scenarios... which is great until you want it to lock-up under load.
I have only notionally looked into how to make this function "properly".
Reactions: 64nailhead
<= THIS GUY!
Where in the H E double hockey stick do you get all this knowledge from?
Reactions: Tony1968
