Crossmember selection depends upon where the engine and transmission sit together in the chassis. If the setback plates locate the back of the block where the trans mates as close to that of the old 305, that simplifies your life. From the attached TCI transmission dimensions page, the mounting pad on the trans is 21-3/4" from the back of the block; on a 700R4 it's 22-1/2" ; on a TH350, it's 20-3/8". I measured a 350 I had in the garage. The upper rear motor mount shell bolt hole on the passenger side is 14" to the back of the block. Measure the length same location on your adapter plate to the back of the block. If it's 14", then this plus 21-3/4" will define where the trans mount pad will be in your car. Using the transmission dimensions I listed above, choose the crossmember that places the transmission pad bolt hole within a half-inch (forward/aft), since you can file out the hole a bit and still have strength to hold it in place. For example, if it's 14+19-3/4" to 14+ 20-3/4", I'd choose a crossmember designed for use with a TH350.
