8) Hi, I plan on doing a LS1 rear disc brake swap, just wondering size tire (rim Size) 15", 16, 17" ????
any body do the swap, what size are you using.Ray
but you will probably not be able to use any stock 15" wheel, some aftermarkets work, but for sure 16" or larger should work with no issue.
also if you are going to upgrade the front brakes you may want to research that a little, cause some of the corvette style calipers wont allow anything smaller than a 17"-18
