MONTE CARLO LS3/6L80 swap
Looks like they did a great job. Can you please post more pictures of how your cold air intake goes through the radiator support? Where did you buy the intake? Looks like a nice piece.
The shop made the intake pipe (aluminum I believe and painted). Used the supplied air filter from the ERod package, which is passed thru existing opening in the radiator support bracket made to hold onto radiator support.
What kind of clamps are those on the upper radiator hose?
The shop said they are heat shrink clamps. They are not suppose to leak and neater appearance. Down fall is that you have to cut them to remove hose. That is what they use on all there builds and have had no problems. They are called gates powergrip clamps. JEGS carries them.
