LS3 Injectors
MechMan
MechMan
260
Long Island NY
I am planning on building a LS3 and I am trying to decide if the stock injectors would be enough. I am shooting for around 600hp but I’m not married to that number. It will be a non stroked motor. I know stock is 42lbs what size should I go with. The motor will be N/A. I would rather not change them out after the fact. Also what injector companies does everyone recommend
Anubis
Anubis
1,857
For my Z71 turbo project I plan on de capping some plain Jane used truck injectors and have them flowed.
You can spend serious money on injectors. Silly really since de capping them has been done successfully on many builds.
Turbolq4
Turbolq4
1,501
Nampa Idaho
600 is alot for being NA. Decapped truck injectors work in boosted application but I wouldn't want to use them like this. The spray pattern is a stream instead of a cone.
60lb/hr would be Overkill but also have room to grow and would be running at reasonable duty cycles. I run Deka 80s on my Malibu but have no experience with big power na stuff so can't recommend a particular brand.
MechMan
MechMan
260
Long Island NY
I realize 600 is a lot for N/A I doubt I’ll get that high but I would like it in the upper 500’s which I believe is definitely doable. Just don’t want to starve the engine and I don’t want to go over 80% duty cycle.
Thread starter Similar threads Forum Replies Date
A G-Body LS Swap 8
MechMan G-Body LS Swap 2
MechMan G-Body LS Swap 11
MechMan G-Body LS Swap 5
