http://www.ebay.com/itm/MSD-Ignition-60 ... _499wt_924
The MSD 6012 is usually used when going carbed. It also states that the controller can be used on efi engines. The controller only controls ignition and timing. I was wondering if you stayed efi could it be possible to use the 6012 instead of going through the hassle of buying or modifying a harness and getting computer flashed? I dont see why it wouldnt work. This would let me keep fuel injection, make tunes adjustments myself instead of sending in for a tune.
My only concern is with the fuel system. I know either way I need electric fuel pump and regulator. My concern is with controlling the injectors. I can get the fuel to the motor but wondering how to control the fuel supply as needed per duty cycle.
