Ok so ive been on Google for the past two days searching on how to wire up an ignition panel for my Monte and have removed the switches in the car to see what wires are powered when ignition is on and running. Also i have the wiring diagram on what wire does what, thanks to 85 Cutlass Brougham, and im pretty sure on what to do but i want to do it without turning my car into a fireball. I want to know on these drag cars when you flip one switch and it acts like the first turn of the key, do i need a certain amp switch and wire it directly or do i need a relay? I have the start button figured out but i want a switch for ACC, ignition, start, lights,hi/low beam, and turn signals. Any help or suggestion would be great if i get nothing here ill try the speed shops in town. Thanks
