how do the roof rack mount to the roof? the wagon i might be gettin dont have them but i can get one from a ponntiac wagon at my local bone yard
o ok guess ill find out when i go get the other roof rack.. thanks for the info..1badbu said:Under the rail " stands or legs " there is a rubber groment with a threaded barrel.The screws go thru the stand/leg into this groment and pull tension downwards to secure it.
There is a gasket between the stand/leg and roof.
The center rails have a full length gasket and screws.
kuruption109 said:it had a rack and it was removed but the holes were not welded there jus there
Blake442 said:kuruption109 said:it had a rack and it was removed but the holes were not welded there jus there
Well in that case throw one on there!
