I've posted many times about the conversion we did with the C5 fronts and Seville rears. 285's on the rear and 275's on the front - fargin' yikes would that thing stop easily. The low profile tires put handle into the term handling as well. I'm sure you'll be happy once you get it dialed in/completed.Thanks,
Maybe the 82 wagon is a better way to go as I believe I have the larger booster.
I’m sure the seville and LS1/C5 rear caliper pistons ave very similar in size.
Yes, you need a minimum of 17” wheels for the LS1 or C5 rear discs brakes as the brake discs are 12” diameter.
