I hope this is the right section for this. I came across a conversion pedal/clutch kit for the Gbodies and it just dawned on me that the clutch system is not hydraulic...its an assembly of levers and linkages which go straight to the clutch fork. This makes the swap seem MUCH more straight forward since I dont have to drill and mount a master cylinder etc.
Before I ramble too much, I wanted to ask if anyone was familiar with a how-to for this conversion. What I have yet to figure out is which trannys will not support this linkage-clutch set up. Originally I was looking for an s10 t5 or fbody t5 but I'm not sure if those require a hydraulic clutch or what.
I'll settle for a 4 speed, they are just hard to find.
thanks
edit- I did find some how-to's.
http://www.garage-scene.com/t5-into-ag-body/
http://www.monte-list.nu/tech/fivespeed.shtml
http://www.montecarloss.com/ls1montecarloss/
thanks
