Hello Everyone, so I finally got the G Body running but I must say I was REALLY DISAPPOINTED on the performance before and after the bolt on parts as I have read the difference is night and day, & yes I know its a 305 but it just seems like the is some lag off the line & lacks any sort of pep, I feel like i' driving a 4 cyl 1.5 Civic.
So I am thinking maybe I did not set the timing right or it needs more timing?
Currently, the timing is set to 6 degrees BTDC which is what the Haynes book says the OE timing is.
How I set the timing, basically plugged every vacuum line & turned on the car. I set the timing to zero using the timing gun and moving the distributor, then I set the timing gun to 6 degrees and moves the distributor until it read zero on the harmonic balancer & called it good.
Currently, the car idles at about 500 RPM after it warms up but it struggles to stay on at idle, it seems like its a little happier at 650 - 700ish RPM. When I bought the car and before any of the bolt-ons the idle screw was set all the way back as in zero idle adjustment was needed, but i dont remember the rpm's it idled at.
I thought about moving the idle screw in to get the RPM's happier at idle but again my gut tells me it needs more timing or i didn't set the timing correctly.
So my question is, was my timing procedure correct, if not where did I go wrong? Whats the right procedure?
Second, should I put more timing into it (10 12 degrees BTDC) or is there something else going on that is hindering performance?
Spec's:
305 L69, with all the Smog Components.
I believe previous owner rebuilt it in the late 90's & bored it out like .020" over.
Hardland Sharp Rockers (was not able to tell the ratio as they are not marked but i think they are 1.5)
I am sure he upgraded the springs as well but not sure.
My mods:
Edelbrock TES Headers (w/ Y pipe) , Stock Exhaust System
Edelbrock 3701 Intake
Comp Cam & Lifters Xtreme Energy 262H (Lift .462/.469, Duration 262/270, P/N CL12-238-2)
Comp Cam Double Roller Timing Chain (Set at zero)
NGK UR4 Plugs with 8mm Taylor Wires
Spec's:
My mods:
