UPDATE:
So for those following with the same issues/question, a member from a different forum pointed out if you still have your OEM Emissions Sticker it actually gives you the procedure. If you don't have it, go to OPGI.com and search decal emissions for your car & you can see the procedure.
I realized my mistake, the plug(s) I was disconnecting and messing with were the wrong ones. I should have paid more attention but on the driver side of the distributor NONE of those wires that plug into the distributor on that side are 4 wires, they are 3 wire or less.
The wires/plug I needed to disconnect was more on the passenger side of the distributor. As many had said, its a 4 wire plug that comes out of the bottom portion of the distributor with a black plug (maybe 2.5" long) that that has all 4 pins in a straight row & that plugs into the wiring harness.
Below is the picture and the stated process.
Can't say I understand the verbiage entirely, so if someone can translate those 4 steps in lamest terms that would help.
Thank you all!
