Picked this up for $6500.00 just hit it at the right time 700 hp should not be a problem with all the upgrades,cam and machine shop work. This is a brand new motor not even broken in but the po throw in the break-in oil.
Brand new motor; never been run since built. Balanced and blueprinted. Everything in motor are top of the line parts. Estimated 700 horsepower on pump gas.
• 509 Cubic Inches
• Holly 950 Double Pumper Mechanical Secondary Carburetor
• Merlin Intake Manifold
• Pro Topline Aluminum Heads
• Forged Mini Dome Pistons (10 1/2 - 1 Compression)
• Forged Millidon Rods
• Crane Billet Hydraulic Roller Cam
• Crane Aluminum Roller Rockers
• Complete motor assembly with ARP bolts
• 4 Bolt Main Steel Crank
• Billet Double Roller Timing Chain
http://m.summitracing.com/parts/crn-139651
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 3,000-6,400
Intake Duration at 050 inch Lift: 244
Exhaust Duration at 050 inch Lift: 256
Duration at 050 inch Lift: 244 int./256 exh.
Advertised Intake Duration: 306
Advertised Exhaust Duration: 318
Advertised Duration: 306 int./318 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.632 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.632 in.
Valve Lift with Factory Rocker Arm Ratio: 0.632 int./0.632 exh.
Lobe Separation (degrees): 114
Computer-Controlled Compatible: No
__________________
• 509 Cubic Inches
__________________
